Of course there is only 12v and a few watts going into this switch, so I'm not worried about it hurting me, but I don't want it to hurt it'self. I can feel quite a sharp, constant sting if I touch the back of my hand to the casing.
Surely this isn't normal? Why would the case be live?
Could be that something else may have a power supply fault.
Unplug all data cables from it and try your test again. Get a cheap voltmeter or even a neon-bulb tester instead of using your hand. You aren't feeling 12V. You are feeling line voltage...
It happens whaen nothing but the power lead is connected.
Are you talking about a digital multi-meter? What do I measure to?
Use a voltmeter, digital multimeter set to AC volts.
Touch one lead to exposed (not painted) metal on the case. The other to AC mains ground.
If you see AC voltage, you have a bad power supply.
Yeah, I get ~90V between the casing and ground. I guess I'll send the lot back (HP can replace the switch too, on the off chance it was damaged by the power supply).
I think that because you are feeling a tingling that you aren't seeing "phantom" voltage. To be sure, switch the meter to ammeter mode and start on a high range, then step down to see how much current is flowing.
