[378.56]OpenVPN Client 1 - Error connecting - IP/Routing conflict
chrisloup
any clue what it means? however, it does seem to be working
Statistics
TUN/TAP read bytes
910,054 TUN/TAP write bytes 9,632,184
TCP/UDP read bytes 10,196,067 TCP/UDP write bytes 1,261,535
Auth read bytes 9,632,494 pre-compress bytes 82,451
post-compress bytes 77,845 pre-decompress bytes 17,026
post-decompress bytes 21,748
Nov 3 07:56:12 rc_service: service 10492:notify_rc updateresolv
Nov 3 07:56:12 dnsmasq[10411]: exiting on receipt of SIGTERM
Nov 3 07:56:12 dnsmasq[10498]: started, version 2.75 cachesize 1500
Nov 3 07:56:12 dnsmasq[10498]: warning: interface ppp1* does not currently exist
Nov 3 07:56:12 dnsmasq[10498]: asynchronous logging enabled, queue limit is 5 messages
Nov 3 07:56:12 dnsmasq-dhcp[10498]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Nov 3 07:56:12 dnsmasq[10498]: read /etc/hosts - 5 addresses
Nov 3 07:56:12 dnsmasq[10498]: read /etc/hosts.dnsmasq - 2 addresses
Nov 3 07:56:12 dnsmasq-dhcp[10498]: read /etc/ethers - 2 addresses
Nov 3 07:56:12 dnsmasq[10498]: using nameserver 198.18.0.1#53
Nov 3 07:56:12 dnsmasq[10498]: using nameserver 198.18.0.2#53
Nov 3 07:56:12 dnsmasq[10498]: using nameserver 8.8.8.8#53
Nov 3 07:56:12 dnsmasq[10498]: using nameserver 8.8.4.4#53
Nov 3 07:56:14 openvpn[10439]: Ignore conflicted routing rule: 173.245.211.3 255.255.255.255 (why? i don't seen any other conflicts)
Nov 3 07:56:14 openvpn[10439]: /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 172.20.16.1
Nov 3 07:56:14 openvpn[10439]: /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 172.20.16.1
Nov 3 07:56:14 openvpn-routing: Configuring policy rules for client 1
Nov 3 07:56:14 openvpn-routing: Creating VPN routing table
Nov 3 07:56:14 openvpn-routing: Removing route for 0.0.0.0/1 to tun11 from routing tables
Nov 3 07:56:14 openvpn-routing: Removing route for 128.0.0.0/1 to tun11 from routing tables
Nov 3 07:56:15 openvpn-routing: Removing rule 1001 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1002 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1003 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1004 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1005 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1006 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1007 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1008 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1009 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1010 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1011 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1012 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1013 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1014 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1015 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1016 from routing policy
Nov 3 07:56:15 openvpn-routing: Removing rule 1017 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1018 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1019 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1020 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1021 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1022 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1023 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1024 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1025 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1026 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1027 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1028 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1029 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1030 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1031 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1032 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1033 from routing policy
Nov 3 07:56:16 openvpn-routing: Removing rule 1101 from routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 5.42.160.0/20 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 5.42.176.0/32 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 5.42.176.0/20 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 5.42.192.0/32 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 185.60.112.0/23 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 185.60.114.0/32 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 185.60.114.0/23 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 185.60.116.0/32 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 12.129.222.0/23 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 12.129.224.0/32 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 12.129.254.0/23 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 12.130.0.0/32 through WAN to routing policy
Nov 3 07:56:17 openvpn-routing: Added 0.0.0.0 to 12.130.244.0/22 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 12.130.248.0/32 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 199.108.32.0/20 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 199.108.48.0/32 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 199.108.48.0/20 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 199.108.64.0/32 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 103.4.114.0/23 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 103.224.165.0/24 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 203.126.27.0/24 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 192.168.1.0/24 to 0.0.0.0 through VPN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 192.168.1.1 to 0.0.0.0 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 180.168.60.134 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 179.43.134.243 through WAN to routing policy
Nov 3 07:56:18 openvpn-routing: Added 0.0.0.0 to 12.130.192.0/18 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 24.130.0.0/16 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 24.105.0.0/18 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 17.0.0.0/8 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 23.192.0.0/11 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 199.30.200.0/22 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 66.6.32.0/20 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 173.194.0.0/16 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 173.252.64.0/18 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 54.228.0.0/15 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Added 0.0.0.0 to 72.21.192.0/19 through WAN to routing policy
Nov 3 07:56:19 openvpn-routing: Completed routing policy configuration
Nov 3 07:56:19 openvpn[10439]: Initialization Sequence Completed
Nov 3 07:56:33 kernel: [truncated] pch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch
Nov 3 07:56:33 openvpn[10439]: event_wait : Interrupted system call (code=4)
Nov 3 07:56:33 openvpn[10439]: OpenVPN STATISTICS
Nov 3 07:56:33 openvpn[10439]: Updated,Tue Nov 3 07:56:33 2015
Nov 3 07:56:33 openvpn[10439]: TUN/TAP read bytes,260706
Nov 3 07:56:33 openvpn[10439]: TUN/TAP write bytes,2465526
Nov 3 07:56:33 openvpn[10439]: TCP/UDP read bytes,2621134
Nov 3 07:56:33 openvpn[10439]: TCP/UDP write bytes,363207
Nov 3 07:56:33 openvpn[10439]: Auth read bytes,2465796
Nov 3 07:56:33 openvpn[10439]: pre-compress bytes,52548
Nov 3 07:56:33 openvpn[10439]: post-compress bytes,50814
Nov 3 07:56:33 openvpn[10439]: pre-decompress bytes,3943
Nov 3 07:56:33 openvpn[10439]: post-decompress bytes,5485
Nov 3 07:56:33 openvpn[10439]: END
Nov 3 07:56:35 kernel: [truncated] L/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/npch ==NULL/np
