380.62.1 Wireless problem?
Morphy
Dear all.
I upgraded my Asus RT-AC68u with the last update. Since then I have had serious problems getting my full speed of my wireless network from my Macbook to the router via 5Ghz band.
Normally I get 450Mbps with 5GHz band when I look at my wireless connection ( Can see that via ALT+ pressing the wireless icon in the menu bar ( Screeny attached ) .
Also speedtest.net gives me aprox 303,62Mbit which is my download speed from my ISP :)
When I change my wireless settings on the router - lets say change a channel. Then its impossible to regain 450Mbps ! No matter how I do it, and which settings I try to change back to. Its simply impossible to regain the fast network speed.
If I kill the router by turning it off , power it on.. then everything is back to normal?
It seem to "breake" when settings are changed - and only work again on router reset.?
I just spent like 2 hours trying to solve it by changing settings , and found out a power off-on solved the problem.
Any ideas why this happens? I run macOS Sierra version 10.12 .
Thanks for the firmware updates :) good work.
Kind regards
Morphy
You're not noticing anything special. A reboot (not a 'router reset') is required if you want to test different settings in a consistent manner. :)
A 'hard reboot' is also recommended. That is pulling the ac power cord, waiting a few minutes and then plugging it back in. Then, wait at least 5 minutes for the router to settle after it's boot up sequence is complete. ;)
Ahhh ok :) thanks. Actually didn't think of that it needed a reboot when the settings was changed? :)
Gonna try it out ^^
Cheers
