manuelreinaldo
Hi, I have a dd_wrt router with a openvpn 2.3 server and merlin 380.64_2 openvpn client. It works.
I upgraded to version 380.65_2 (with openvpn client version 2.4) and it stopped working.
It connects (according to the log) but I have not connection to the remote subnets. Both logs look very similar in fact.
These are the server and client setups as well as the logs from the Merlin 64_2 and 65_2 versions.
64_2 logs (version that works)
Mar 22 13:35:28 openvpn[927]: OpenVPN 2.3.14 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Jan 7 2017
Mar 22 13:35:28 openvpn[927]: library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.08
Mar 22 13:35:28 openvpn[929]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Mar 22 13:35:28 openvpn[929]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar 22 13:35:28 openvpn[929]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Mar 22 13:35:29 openvpn[929]: UDPv4 link local: [undef]
Mar 22 13:35:29 openvpn[929]: UDPv4 link remote: [AF_INET]xx
Mar 22 13:35:29 openvpn[929]: TLS: Initial packet from [AF_INET]xx, sid=xx
Mar 22 13:35:29 openvpn[929]: VERIFY OK: depth=1, C=XX, ST=XX, L=XXXX, O=XXX, OU=XXX, CN=XXX, name=XXX, emailAddress=xxx
Mar 22 13:35:29 openvpn[929]: VERIFY OK: depth=0, C=XX, ST=XX, L=XX, O=XX, OU=XX, CN=XX, name=XX, emailAddress=XX
Mar 22 13:35:30 openvpn[929]: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mar 22 13:35:30 openvpn[929]: WARNING: INSECURE cipher with block size less than 128 bit (64 bit). This allows attacks like SWEET32. Mitigate by using a --cipher with a larger block size (e.g. AES-256-CBC).
Mar 22 13:35:30 openvpn[929]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mar 22 13:35:30 openvpn[929]: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mar 22 13:35:30 openvpn[929]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mar 22 13:35:30 openvpn[929]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Mar 22 13:35:30 openvpn[929]: [XX] Peer Connection Initiated with [AF_INET]XX.
Mar 22 13:35:33 openvpn[929]: SENT CONTROL [XX]: 'PUSH_REQUEST' (status=1)
Mar 22 13:35:33 openvpn[929]: PUSH: Received control message: 'PUSH_REPLY,route 192.168.5.0 255.255.255.0,dhcp-option DNS 192.168.5.1,sndbuf 393216,rcvbuf 393216,route-gateway 192.168.6.1,topology subnet,ping 10,ping-restart 120,ifconfig 192.168.6.10 255.255.255.0'
Mar 22 13:35:33 openvpn[929]: Options error: option 'route' cannot be used in this context ([PUSH-OPTIONS])
Mar 22 13:35:33 openvpn[929]: Options error: option 'dhcp-option' cannot be used in this context ([PUSH-OPTIONS])
Mar 22 13:35:33 openvpn[929]: OPTIONS IMPORT: timers and/or timeouts modified
Mar 22 13:35:33 openvpn[929]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Mar 22 13:35:33 openvpn[929]: Socket Buffers: R=[122880->245760] S=[122880->245760]
Mar 22 13:35:33 openvpn[929]: OPTIONS IMPORT: --ifconfig/up options modified
Mar 22 13:35:33 openvpn[929]: OPTIONS IMPORT: route-related options modified
Mar 22 13:35:33 openvpn[929]: TUN/TAP device tun11 opened
Mar 22 13:35:33 openvpn[929]: TUN/TAP TX queue length set to 100
Mar 22 13:35:33 openvpn[929]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mar 22 13:35:33 openvpn[929]: /usr/sbin/ip link set dev tun11 up mtu 1500
Mar 22 13:35:33 openvpn[929]: /usr/sbin/ip addr add dev tun11 192.168.6.10/24 broadcast 192.168.6.255
Mar 22 13:35:35 openvpn[929]: /usr/sbin/ip route add 192.168.5.0/24 metric 1 via 192.168.6.1
Mar 22 13:35:35 openvpn[929]: /usr/sbin/ip route add 192.168.3.0/24 metric 1 via 192.168.6.1
Mar 22 13:35:35 openvpn-routing: Skipping, client 1 not in routing policy mode
Mar 22 13:35:35 openvpn[929]: Initialization Sequence Complete
65_2 logs (version that doesn't works)
Mar 22 13:22:19 openvpn[3360]: OpenVPN 2.4.0 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Mar 10 2017
Mar 22 13:22:19 openvpn[3360]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.08
Mar 22 13:22:19 openvpn[3361]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Mar 22 13:22:19 openvpn[3361]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar 22 13:22:19 openvpn[3361]: TCP/UDP: Preserving recently used remote address: [AF_INET]xx
Mar 22 13:22:19 openvpn[3361]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Mar 22 13:22:19 openvpn[3361]: UDP link local: (not bound)
Mar 22 13:22:19 openvpn[3361]: UDP link remote: [AF_INET]XX
Mar 22 13:22:19 openvpn[3361]: TLS: Initial packet from [AF_INET]XX, sid=xx
Mar 22 13:22:20 openvpn[3361]: VERIFY OK: depth=1, C=XX, ST=XX, L=XX, O=XX, OU=xx, CN=xx, name=xx, emailAddress=XX
Mar 22 13:22:20 openvpn[3361]: VERIFY OK: depth=0, C=xx, ST=xx, L=xx, O=xx, OU=xx, CN=xx, name=xx, emailAddress=xx
Mar 22 13:22:21 openvpn[3361]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Mar 22 13:22:21 openvpn[3361]: [xx] Peer Connection Initiated with [AF_INET]xx
Mar 22 13:22:22 openvpn[3361]: SENT CONTROL [xx]: 'PUSH_REQUEST' (status=1)
Mar 22 13:22:22 openvpn[3361]: PUSH: Received control message: 'PUSH_REPLY,route 192.168.5.0 255.255.255.0,dhcp-option DNS 192.168.5.1,sndbuf 393216,rcvbuf 393216,route-gateway 192.168.6.1,topology subnet,ping 10,ping-restart 120,ifconfig 192.168.6.10 255.255.255.0'
Mar 22 13:22:22 openvpn[3361]: Options error: option 'route' cannot be used in this context ([PUSH-OPTIONS])
Mar 22 13:22:22 openvpn[3361]: Options error: option 'dhcp-option' cannot be used in this context ([PUSH-OPTIONS])
Mar 22 13:22:22 openvpn[3361]: OPTIONS IMPORT: timers and/or timeouts modified
Mar 22 13:22:22 openvpn[3361]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Mar 22 13:22:22 openvpn[3361]: Socket Buffers: R=[122880->245760] S=[122880->245760]
Mar 22 13:22:22 openvpn[3361]: OPTIONS IMPORT: --ifconfig/up options modified
Mar 22 13:22:22 openvpn[3361]: OPTIONS IMPORT: route-related options modified
Mar 22 13:22:22 openvpn[3361]: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mar 22 13:22:22 openvpn[3361]: WARNING: INSECURE cipher with block size less than 128 bit (64 bit). This allows attacks like SWEET32. Mitigate by using a --cipher with a larger block size (e.g. AES-256-CBC).
Mar 22 13:22:22 openvpn[3361]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mar 22 13:22:22 openvpn[3361]: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mar 22 13:22:22 openvpn[3361]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mar 22 13:22:22 openvpn[3361]: WARNING: cipher with small block size in use, reducing reneg-bytes to 64MB to mitigate SWEET32 attacks.
Mar 22 13:22:22 openvpn[3361]: TUN/TAP device tun11 opened
Mar 22 13:22:22 openvpn[3361]: TUN/TAP TX queue length set to 100
Mar 22 13:22:22 openvpn[3361]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Mar 22 13:22:22 openvpn[3361]: /usr/sbin/ip link set dev tun11 up mtu 1500
Mar 22 13:22:22 openvpn[3361]: /usr/sbin/ip addr add dev tun11 192.168.6.10/24 broadcast 192.168.6.255
Mar 22 13:22:24 openvpn[3361]: /usr/sbin/ip route add 192.168.5.0/24 metric 1 via 192.168.6.1
Mar 22 13:22:24 openvpn[3361]: /usr/sbin/ip route add 192.168.3.0/24 metric 1 via 192.168.6.1
Mar 22 13:22:25 openvpn-routing: Skipping, client 1 not in routing policy mode
Mar 22 13:22:25 openvpn[3361]: Initialization Sequence Completed
The server configuration is:
daemon
server 192.168.6.0 255.255.255.0
proto udp
port 1194
dev tun
keepalive 10 120
verb 4
push "route 192.168.5.0 255.255.255.0"
route 192.168.4.0 255.255.255.0 192.168.6.10
duplicate-cn
push "dhcp-option DNS 192.168.5.1"
client-to-client
tun-mtu 1500
mssfix 1460
topology subnet
mute 5
sndbuf 393216
rcvbuf 393216
push "sndbuf 393216"
push "rcvbuf 393216"
client-config-dir /tmp/openvpn/ccd
ca /tmp/openvpn/ca.crt
cert /tmp/openvpn/cert.pem
key /tmp/openvpn/key.pem
dh /tmp/openvpn/dh.pem
comp-lzo
The client configuration (in both cases, 64_2 and 65_2)
proto udp
remote XX
route-nopull
route 192.168.3.0 255.255.255.0
port 1194
tun-mtu 1500
mssfix 1460
nobind
resolv-retry infinite
route-metric 1
float
verb 3
And also, in the client I have the option to redirect all internet traffic set to "no" and I have the option to accept DNS configuration as no.
With this, when I try to connect to any ip in 192.168.5.x or 192.168.3.x with the new firmware it doesn't work.
I reverted back to 380.64_2 and it works again.
Thanks for the help
daemon
proto udp
port 1194
dev tun
keepalive 10 120
verb 4
duplicate-cn
client-to-client
tun-mtu 1500
mssfix 1460
topology subnet
mute 5
sndbuf 393216
rcvbuf 393216
comp-lzo
proto udp
remote XX
route-nopull
port 1194
tun-mtu 1500
mssfix 1460
nobind
route-metric 1
float
verb 3
Thanks for the help
