There seems to be some ongoing issue with the display of the clients in the network map page. It existed in beta 2 and is here as well.
I always seem to have 1 or 2 Ethernet wired clients displaying with the tag STATIC in the client IP address field of the VIEW LIST that are not static. These erroneously displayed devices are within the DHCP range, and are NOT bound to the Mac address. The should be displaying with the DHCP tag/Automatic IP.
Its not necessarily the same devices all the time either as I have seen the Static tag appear on different devices and then have resolved when I check again the next day. Not sure what is causing this.
I do have 5 devices where I am using the "Manually Assigned IP around the DHCP list" feature . But these appear to be constant so far and correctly displayed.
I am pretty sure I have seen this behaviour with the non-beta firmware too. Does anyone have any ideas as to the cause? or what else to try and test?
Many thanks
Edward
Many thanks
Edward
