380.68 Traffic Analyzer Broken
hyelton
I thought I'd finally update, 2 or so updates behind. Did a factory reset and a clean setup. Now realizing 3 days later Traffic Analyzer is broken (It may had been when I flashed as well) I normally use the Adaptive QoS page to see current traffic, but both Traffic Analzyer And the more important Daily traffic usage is broken. The upload is mirroring the download. Like today its showing I've used 20GB of usage both upload and download which is not the case.
Is this a known issue?
Thanks.
EDIT: After disabling NAT Acceleration it fixed it
Are you using a VPN? This can mess with traffic usage numbers.
Thanks.
I have the same issue on my RT AC88U
I had this same issue a month or two ago
Factory reset & New firmware fixed it,
