Is it normal to have a corrupted sort order in a System Log file? I examined this log shortly after rebooting the system. I assume it sorts on date? The attached photo is just one example.
The day before I had downgraded the system from 380.68_2 to _0 due to problems with a manually assigned IP Grandstream HT702 VOIP ATA not being able to recover reliably after a cable modem WAN outage and recovery. Not sure if the downgrade causes the log file issue?
