382.1.2 ac3100 wireless latency issues
agilani
I need assistance with some pretty bad wireless latency on 382.1.2 (entire 382 branch really) on my ac3100. After upgrade from 380.69 (and earlier 380 revs) the device for the most part acts noramlly. After about 1/2 a day though wireless latency and response times go through the roof. Basically from sub 10ms latency to 200+ ms latency. It appears to be limited to wireless only. This is the second time i had to go back to the 380 branch of the code. Any help or advice would be appreciated.
many thanks,
I have the same router as you and have no problems. I am using the most recent 384.3 alpha 2. Have you tried a restore to factory defaults?
I also have 3100 running 382.1_2 and do not have the issue you are experiencing. I also performed a restore to default after flashing from 380 to 382.
Thanks for the feedback. I have not restored to default. It was a dirty flash. Mabye I'll try the 384 branch and see if i experience the same issues.
