384.13: Issue with route automatically generated for OpenVPN client
Bohdan
I am running an OpenVPN server with client config files for each client (clients are routers of my parents with networks behind them). These configs have IP addresses assigned to each common name.
On previous versions of the firmware, the real client IP addresses were taken into account when adding gateway entries to routing table, and now the client addresses are wrong which doesn't let me access the network behind the client unless I ssh into my router and remove wrong route and add a correct one like this:
route del -net 10.0.20 0 gw 10.8.0.2 netmask 255.255.255.0 dev tun21
route add -net 10.0.20.0 gw 10.8.0.102 netmask 255.255.255.0 dev tun21
Besides, all my clients are added with the same gateway IP: 10.8.0.2 while they have different IPs assigned in openvpn ccd files (10.8.0.101, 10.8.0.102 etc).
I think this is a bug. If not, please tell me what I could do wrong. I didn't touch the config for a long time and got this issue after Merlin firmware update to 384.12 or 384.13 (don't know exactly).
Thank you!
ColinTaylor
Part of the Furniture
I don't have a solution to your problem but I'd guess that this was introduced in 384.12.
384.12 (22-June-2019)
  - CHANGED: Reworked handling of up/down events in OpenVPN.
             Server instance will now also use its own
             updown script, which will handle firing up
             openvpn-event (if present).
Xentrk
Thank you!
What @ColinTaylor says may be correct.
I recommend you create an /jffs/scripts/openvpn-event script and place the contents in the post link below inside openvpn-event:
https://www.snbforums.com/threads/f...lts-releases-v39e3.18914/page-238#post-294825
Then, create the file /jffs/scripts/vpnserver1-up and place the routing commands inside the file. Make sure you had the she-bang (#!/bin/sh) at the top and make it executable (chmod 755 vpnserver1-up). This will run the routing commands during vpn server start-up.
Bohdan
Thanks for the workaround advised. I've already had a openvpnserver1-client-connect script which was called by a "client-connect /jffs/scripts/openvpnserver1-client-connect" directive in custom config for OpenVPN server so I added those entries there.
Seems to do the trick for now. Thanks!
