octopus
https://onedrive.live.com/?authkey=!AGY2taGX02nVmWA&id=CCE5625ED3599CE0!1427&cid=CCE5625ED3599CE0
Keep in mind its early testbuild without any support.
https://asuswrt.lostrealm.ca/download
Alpha 1
RT-AC68U for now. - 384.14_alpha1-g8e96494aae Have some bug(s)
RT-AC68U new build. - 384.14_alpha1-gad8d31dff5 Merge with GPL 384_81049 (from RT-AC68U)
RT-AC88U new build. - 384.14_alpha1-gb2338312cd
Alpha 2 -1
RT-AC68U
RT-AC88U
RT-AC3100
RT-AC86U
RT-AX88U
Alpha 2-2
RT-AC68U
RT-AC88U
RT-AC3100
RT-AC86U
RT-AX88U
Change log Alpha 2-1
- UPDATED: RT-AC68U, RT-AC88U, RT-AC3100 to GPL 384_81116.
- UPDATED: RT-AC86U to GPL 384_81116 + binary blobs from 384_81049
- NOTE: There is currently no builds available for the RT-AC87U,RT-AC3200 or RT-AC5300
due to lack of updated compatible components from Asus.
- UPDATED: RT-AX88U to GPL 384_6436.
- UPDATED: nano 4.4
- UPDATED: OUI database to 2018-08-17 version
- UPDATED: Curl 7.66.0
RT-AX88U to match other models.
- CHANGED: Moved /usr/bin/ip to /usr/sbin/ip on the RT-AC86U and
models.
- FIXED: Backported various httpd fixes to RT-AX88 from other
Change log Alpha1
384.14 (xx-xxx-xxxx)
- NEW: Implement option to prevent Firefox's automatic usage of DoH.
By default, this will only apply if you have DNSPrivacy
enabled, or if you have DNSFilter enabled with a global
filter, to ensure that Firefox will not bypass either of
these. You can also have this override applied all the
time, or completely disable it.
- UPDATED: miniupnpd 20190824
- UPDATED: dnsmasq 2.80-74-gdefd6b1 (themiron)
- UPDATED: OpenSSL 1.0.2 to 1.0.2t (themiron)
- UPDATED: OpenSSL 1.1.1 to 1.1.1d (themiron)
- CHANGED: Made webui SSL certificate generation compliant with
IOS 13 and MacOS 10.15 new requirements.
- CHANGED: Rewrote the faketc script used to inject Codel into
Adaptive QoS as a C program for improved performance.
- CHANGED: Moved /bin/ip to /sbin/ip on the RT-AC86U and RT-AX88U
- FIXED: Webui wouldn't notify when running dangerously low on
free nvram (feature was lost at some point in the past)
- FIXED: Non-working link to YandexDNS on the webui for
Russian models.
Alpha 1
Alpha 2 -1
RT-AC68U
RT-AC88U
RT-AC3100
RT-AC86U
RT-AX88U
Alpha 2-2
RT-AC68U
RT-AC88U
RT-AC3100
RT-AC86U
RT-AX88U
- UPDATED: nano 4.4
models.
Change log Alpha1
Russian models.
