384.15 - amtm added to the firmware?
Ben_
Does that mean one no longer needs the use of USB?
I'm currently on 384.14_2 and Diversion/amtm is on a USB stick. When I install/upgrade to 384.15, do I just remove the USB stick and amtm/Diversion will be transferred to my router automatically?
No. You still need a usb drive for the scripts.
All this does is make the initial setup easier as you don't need the additional step of installing amtm via the command line as it's built into the firmware. For those with amtm and scripts already installed there is basically nothing extra to do. Just keep on truckin'.
Thanks, I'm lazy and I'm glad that I don't have to do anything, lol:)!
