384.16 Outbound VPN Connection Issues
jderosa3
I am working from home and VPN to my office has been fine until I upgraded to 384.16 on my RT-AC86U router. If I connect and disconnect. The VPN client will not reconnect again until I reboot my router. Is this a known issue or is there something I should check?
Are you running the VPN client on your router, or are you running a VPN app on your PC?
If it is a VPN app is it an app provided by your business?
With a little more information someone here can make some suggestions.
i've had no issues on my end using my company's VPN app, or the vpn client through the router.
Maybe the issue is with your VPN service. Try to connect using the hotspot feature on your phone. My company only has 60k slots, so we have to keep trying to connect during the morning hours...
