[384.8_Alpha - builds] Testing all variants.
DonnyJohnny
384.8_a”alpha1-g624b4d4e running well. Dirty flashed from 384.7
Thanks!
In Webgui, under Wireless. Roaming Block list??
Not needed as AiMesh not supported?
Thanks!
+1 !
Lots of white ‘blank’ fields in the administration > system GUI page. ;-)
Not affecting operation though, so far as I can see.....
Edit: not just the admin>system page. Fairly widespread throughout the GUI.
I guess that’s what you get with alpha firmware, serves me right!
+1 !
Kindly explain blank space. Screenshot? I don’t see any in my Ac68u. All good.
Hmm seems am not thredowner any more..... Stange I started it. :eek:
Rmerlin when asuswrt-merlin 384_8 alpha 1 for RT-AC87U will be available?
Trimis de pe al meu ONEPLUS A3000 folosind Tapatalk
Lots of white ‘blank’ fields in quite a few pages QOS,Other settings,Wireless, etc
on almost every page - an example below
Try with ctrl-f5 to refresh cash.
Curious, what is this log entry referring to?
May  5 01:05:09 avahi-daemon[774]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Or this one?
May  5 01:05:11 ERP: The model isn't under support list!
.8 running fine here on a fairly simple config with only various port forwarding enabled.
+1 !
I'm seeing the same white spaces here on a AC3100.
Clear your browser cache.
Wow! Rebooted and white space is gone!!
How is WiFi stability on this alpha thus far?
GPL 32799, which Asus hasn’t released yet, has a “WiFi Stability Fix” listed in release notes. I was wondering if previous GPL has any WiFi oddities going on.
Thanks!
Thanks!
So far I have had zero issues with wifi. I had a white space issue in the webui but it was corrected by clearing browser cache.
