386.3_2 ac86u cannot use openvpnclient
franksz
syslog:
Aug 9 21:09:28 rc_service: httpd 1343:notify_rc start_vpnclient5
Aug 9 21:09:28 opnvpn: Starting OpenVPN client 5 failed!
Aug 9 21:09:28 opnvpn-routing: Clearing routing table for VPN client 5
Aug 9 21:10:01 rc_service: httpd 1343:notify_rc start_vpnclient5
Aug 9 21:10:01 openvpn: Starting OpenVPN client 5 failed!
Aug 9 21:10:01 openvpn-routing: Clearing routing table for VPN client 5
Aug 9 21:10:41 rc_service: httpd 1343:notify_rc start_vpnclient5
Aug 9 21:10:41 openvpn: Starting OpenVPN client 5 failed!
Aug 9 21:10:41 openvpn-routing: Clearing routing table for VPN client 5
But with the same configuration, openvpn can be used normally under windows or official firmware,How to solve?
eibgrad
There's no way to tell based on the provided information. When the syslog is so non-specific, it usually means it's a very basic error (syntax, missing directive, etc.), so it can't even be started. We need to see the details of the configuration to make progress.
franksz
ovpn file:
client
proto tcp
dev tun
resolv-retry infinite
nobind
persist-key
persist-tun
comp-lzo
verb 3
route-method exe
route-delay 2
remote *.*.*.* 1194
ca ca.crt
cert frank.crt
key frank.key
Entered in "Keys and Certificates", ca.crt frank.crt frank.key.
franksz
Can you give me some help? thanks
RMerlin
Asuswrt-Merlin dev
Keys and Certificates need to contain actual key/certificate data in PEM format, not a reference to a filename.
