386.4 WAN + Ethernet ports 100Mbps
kenshiroro
Hi
First and foremost, just wanted to say AsusWRT-Merlin has been a godsend since the latest official firmware from Asus has been disconnecting my internet connection ever so often. Having to reboot the router about 6 times or more a day isn't a great experience
Prior to AsusWRT, the WAN and LAN ports are functioning at 1Gbps. After the installation, i see that it has been capped to 100Mbps
I did the usual physical troubleshooting like manual restart, unplug and plug but no changes there
Can someone guide me through connecting to the router via SSH and check if ports are configured to 1Gbps?
Thanks for you time and hope to hear from you soon
bbunge
Part of the Furniture
Router model?
Did you do a full factory reset with manual configuration after installing Merlin?
kenshiroro
Router model?
Sorry i should've added that info
Router is RT-AC86U and no i didn't do a factory reset with manual configuration after installing Merlin.
Just went through the documentation for installation guide (my bad), will do a factory reset. I can do this via the interface as opposed to the reset button at the back?
kenshiroro
Interesting development, the router has been going strong for 21 hours (had to reboot as WAN dropped) and the WAN connection which was 1Gbps earlier today has now reverted to 100Mbps. Bizarre
I have scheduled a reboot every day at 2am so will check again later in the morning
geobernd
I have a somewhat similar observation on my RT-AC68P:
Last week I had the WAN port drop to 100Mbps a couple of times - it seemt to coincide with a short loss of WAN connectivity according to the Log - not sure what triggered it - I could not find any suspicious entries in the Cable Modem Log that would point to a loss of physical connectivity.
Unplugging and replugging the WAN cable brought back 1Gbps...
It has not happened since Friday so I chalked it off to my Cable Modem playing tricks (SB6183) - but maybe there is more to it...
kenshiroro
unfortunately that's a no go for me. as soon as i do that, i will need to go through a series of "connection terminated" and "modem hangup" lines under system log
very frustrating, especially even after manually rebooting the router via the power button at the back it will revert from 1Gbps to 100Mbps once the internet connection is FINALLY successful
is the RT-AC86U that bad of a router? i upgraded this from an RT-AC68U which was rock solid. this model which reviews almost everywhere is deemed as one of the best Asus routers
kenshiroro
Can someone direct me on how i can get started with running a script or scripts?
Someone else having the dame issue but seems to have resolved by running a script(s) to force 1Gbps auto negotiate
L&LD
For basic script installations, the following link may help. Note that you do NOT need to install amtm anymore (skip those steps).
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
For the issues you're describing, have you tried different brands/quality Ethernet cables? Have you tried reversing the cables you have (if you can)? By 'reversing', I mean to physically swap the cable around.
Have you tried unplugging everything from all connections, USB, power cables (and cables/adaptors from the wall AC), and Ethernet cables from the entire network for more than just a few minutes?
What changes did you do after fully resetting the router? What options, features, and other networking devices are connected to your network/router?
kenshiroro
Just tried your troubleshooting steps. The router would initially detect 1Gbps then revert to 100Mbps
Even listed as 100Mbps Full Duplex
I think it has to do with the auto negotiation issue as mentioned from the link i posted
L&LD
And you tried different Ethernet cables?
Do the link speeds stay at 1GbE with a single connection on any of the ports?
Has this router been in a power surge and/or brownout situation?
kenshiroro
Sorry for the late reply, answers as below
1. Yes tried nee cables, no difference
2. All the links are at 100Mbps. They change to 1Gbps when i unplug and replug but would fall back too 100Mbps over time
3. Not that I'm aware of. I am using a surge protector and power hardly cuts off where i sm
