388.1 AX86U Pro AiMesh ethernet backhaul connection
Davev6
I just bought the AX86U Pro and paired it up with my existing AX86S (node). Previously AX86S and AX82U(node) no issues
Router is showing that AX86S is not able to connect to the uplink router (AX86U Pro) via the Ethernet uplink
On the Mobile appI do not see the same error and the node seems to be working properly.
I did factory reset on both routers but issue is still present.
You've missed a bunch of threads and posts dealing with this issue on the RT-AX86U.
Only solution is to run Asus stock firmware on the node - in this case your RT-AX86US.
When I was using 388.1 on the main router - I used Asus stock firmware version 3.0.0.4.388_21709 on the node.
It will get rid of the webui bug which states the Mesh is not properly connected ... but it may not solve connection drops which could well be your next query. As you will see from my signature I reverted to older Merlinware - and enjoy rock solid performance and stability.
