Just switched from Draytek 2130n to Asus RT-N66U.
The reason for switching was the wireless. I have several access points and the Draytek doesn't like it when switching from the internal AP to an external one and blocks Internet access for several minutes (confirmed bug). I have been using that modem for several years in combination with a glass-fibre modem and a 3G USB stick (Huawei E160G) for fallback reasons.
This combination proved to be rock solid.
Now the Draytek has been replaced with the RT-N66. Wifi is a real improvement. The Internet connection is really stable, when the 2nd (3G) WAN connection is not configured. There is only one artifact in the log (second line from the bottom):
Jan 1 01:00:08 kernel: NTFS (with native replay) support included
Jan 1 01:00:08 kernel: optimized: speed
Jan 1 01:00:08 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan 1 01:00:09 stop_nat_rules: apply the redirect_rules!
Jan 1 01:00:09 WAN Connection: ISP's DHCP did not function properly.
Jan 1 01:00:09 RT-N66U: start httpd
It happens only once during boot. The modem acquires an IP address just fine and refreshes it once every hour.
When I configure the 3G fallback connection something different happens. After boot, WAN shows connected and 3G disconnected.
Within a couple of hours this happens:
Jan 19 19:24:28 WAN Connection: ISP's DHCP did not function properly.
Jan 19 19:24:28 stop_nat_rules: apply the redirect_rules!
Jan 19 19:26:32 rc_service: wanduck 320:notify_rc restart_wan_if 0
Jan 19 19:26:32 stop_wan(): perform DHCP release
Jan 19 19:26:32 kernel: Attempt to kill tasklet from interrupt
Jan 19 19:26:33 dhcp client: bound 77.175.185.74 via 77.175.176.1 during 3600 seconds.
Jan 19 19:26:34 rc_service: wanduck 320:notify_rc restart_wan_line 1
Jan 19 19:26:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0__dev_ttyUSB0)!
Jan 19 19:26:34 miniupnpd[2962]: HTTP listening on port 35446
Jan 19 19:26:34 miniupnpd[2962]: Listening for NAT-PMP traffic on port 5351
Jan 19 19:26:41 rc_service: wanduck 320:notify_rc restart_wan_if 1
Jan 19 19:26:41 pppd[705]: Connection terminated.
Jan 19 19:26:42 pppd[705]: Child process /bin/comgt -d /dev/ttyUSB0 -s /etc/ppp/3g/Generic_disconn.scr (pid 2994) terminated with signal 15
Jan 19 19:26:42 pppd[705]: disconnect script failed
Jan 19 19:26:43 stop_wan(): perform DHCP release
Jan 19 19:26:45 pppd[2997]: pppd 2.4.5 started by admin, uid 0
Jan 19 19:26:47 rc_service: wanduck 320:notify_rc restart_wan_line 0
Jan 19 19:26:47 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jan 19 19:26:47 miniupnpd[2962]: received signal 15, good-bye
Jan 19 19:26:48 WAN Connection: WAN was restored.
Jan 19 19:26:49 pppd[2997]: Connect: ppp0 <--> /dev/ttyUSB0
Jan 19 19:26:51 pppd[2997]: Could not determine remote IP address: defaulting to 10.64.64.64
Jan 19 19:26:51 pppd[2997]: not replacing existing default route via 77.175.176.1
Jan 19 19:26:51 pppd[2997]: local IP address 188.91.195.109
Jan 19 19:26:51 pppd[2997]: remote IP address 10.64.64.64
Jan 19 19:26:51 pppd[2997]: primary DNS address 84.241.226.140
Jan 19 19:26:51 pppd[2997]: secondary DNS address 84.241.226.9
This interrupts the Internet connection for a couple of minutes (and worse, the Synology NAS behind the router updates the DDNS registration).
Then everything works normally, except now WAN shows as connected and 3G shows standby.
After 1 to 3 hours this happens again, etc....
Does anyone have any idea what causes this?
Some more observations:
1) Logs say ttyUSB0, even when modem is connected to ttyUSB1 (modem is really on ttyUSB0 now)
2) With comgt the reception strength shows as 21 out of 99. Could it be this is not enough? But if it is, disconnecting the main line while the backup line has a problem is really crappy behavior.
3) Already tried several factory resets
4) Modem is on latest firmware (3.0.0.4.374.2050).
