4/5 BYOD NAS to serve media content
simon76
I'm looking for a NAS device to store video content to be streamed through a wired network to a network media player (currently Egreat EG-M34A and PS3). What I'm looking for is enough bandwidth to provide a good user experience, even for high definition material (1080p) and as inexpensive as possible. The following requirements I'm looking for:
Must:
- sustained read throughput of at least 40 Mbps (with Raid 5)
- Raid 5 capability
- 4/5 drive bays
- BYOD
- quiet enough to be virtually unhearable from 15 meters (ca. 45 feet) distance
- support for 2 terabyte hard drive
Nice to have:
- ability to combine folders from different hard drives to one virtual folder (not JBOD) like the "folder aggregation" feature from QNAP NAS devices
- low energy consumption
A ready NAS solution would be the best, but if building my own NAS would be cost-effective (including the energy costs), I'm open to that alternative as well.
If you use raid 5, there will be only 1 hard driver. You can use a single volume for everything.
Virtually any modern NAS will meet your needs. 40 Mbps is 5 MB/s and there are plenty of products in the NAS Charts that well exceed that performance.
QNAP, Thecus and Synology primarily serve the BYOD NAS market.
Thanks for the replies. I have now limited the choice to the following:
  • QNAP TS-439 Pro (cost including 4 x 2 TB hard drives, 137 Euro per TB)
  • Synology 409 (105 Euro per TB)
  • Synology 409+ (116 Euro per TB)
QNAP is the fastest, has hot-swapping and a metal casing, but is significantly more expensive. On the other hand, I'm already familiar with Qnap, as I have a TS-239 Pro, and quite like it. I guess the most rational solution would be to get the Synology 409, as the read speed over a wired network should be more than enough.
2301 Small (very small) NAS NAS Buying Advice 6
D Quiet NAS / home server NAS Buying Advice 2
