I'm using a ZTE MF833U1 on my RT-AC86U with no issues.Just wondered what usb hardware people use for this?
I use the same device with an RT-AX86U, also no problems.I'm using a ZTE MF833U1 on my RT-AC86U with no issues.
The Zyxel works perfectly with the Asus on one of the lan ports.
I've been using the built-in failover/failback for many months now using a ZTE MF833U1. It has always failed over and back again reliably without any problems.Dual WAN Fail over/back doesn't work reliably on Asuswrt.
This custom script (Asuswrt-Merlin firmware only) was made to address the issue:
Dual WAN Failover ***v2 Release***
WAN Failover is designed to replace the factory ASUS WAN Failover functionality, this script will monitor the WAN Interfaces using a Target IP Address and pinging these targets to determine when a failure occurs. When a failure is detected in Failover Mode, the script will switch to the...www.snbforums.com
Good luck.
Thank you for that.Dual WAN Fail over/back doesn't work reliably on Asuswrt.
Good luck.
Welcome To SNBForums
