kilex00
So, here's how things are.
I have A1's 4G-LTE sim card inserted into ZTE-MF293N modem/router combo.
I've found the direction of towers (1km air line) and when I place the damn thing on the window closest to that, pointing directly towards the towers with its back, the signal is full 6/6 lines.
Now here's the fun part:
> Full signal
> Run speed test
> 5Mbps DL, 15Mbps UP
Now, we move the router to the other window on the wall to the left (so this way, the angle between the towers and the router is ~90 deg +- something.
> Signal 3/6 lines (-108db)
> Run speed test
> 22Mbps DL, 7Mbps UP
Both towers use LTE Bands 3 and 20 and the coverage of my house falls under B20 from one and B3 from the other tower.
Now - here's my question, why tf does the speed drop when the signal is full?
Also, on web ui, I have no way to see other parameters for the signal, just signal strength
> Full signal
> Run speed test
> 5Mbps DL, 15Mbps UP
> Run speed test
> 22Mbps DL, 7Mbps UP
