I'm currently using an ASUS AC5300 router. Prior to that I was using an Asus RT-AC87U and before that an Asus RT-AC66U. With these I have experienced the same issue with the 5Ghz AC radio. Connections using the 5Ghz ac band will consistently fail to maintain connections over time. Sometimes over a short period and sometimes longer. On the other hand, everything that connects to the 2.4Ghz band is rock solid. There are often a large number of devices active at any particular time. The count has been as high as 43. Typically, however it hovers around 25-35. It’s a mix of devices including PC's, laptops, tablets, Androids, iPhones and android phones, Xbox and assorted other consumer devices. To accommodate the continually increasing number of devices and to allow for connections to devices that did not support WI-FI I acquired two (2) RT-AC87U routers setting one up as a wireless bridge for connecting non-wireless devices too far from the main RT-AC87U to use a direct cable. This worked very well with the wireless bridging providing better than 1Gb throughput for some devices. Unfortunately, other devices connected to the same band on 5Ghz still suffered the same disconnect issue as before affecting all devices on the band. It would clear without intervention, usually, but the interruption was always disruptive. Devices connected to the 2.4Ghz band, (N class), remained rock solid without interruption. One of my sons, an avid gamer, acquired an Asus AC1900P to use as a bridge. Connected to the 5Ghz band he had continual issues with disconnects, so much so that I setup a guest network on the 2.4Ghz band just for him. Again, no problems and throughout was adequate.
At this point, thinking that perhaps device count or something related was causing the issue, (I found no issues with signal strength or interference), I acquired the AC5300. I configured one of the 5Ghz bands to use strictly for bridging, and set the other up just for connecting devices. The channel configured for bridging is rock solid. Great throughout, no disconnects solid performance and availability. The 5Ghz channel for devices continues to suffer from the same intermittent disconnects. The 2.4Ghz channel maintains it's consistent availability without disconnects, failures or performance issues.
The main router is located on the second floor of a 2500 square foot house. Signal strength is good throughout the lower floor. Even the basement has good signal strength where a Netgear R6400 is employed as a bridge to support the multimedia room there.
All the Asus routers are running Asus Merlin firmware and have since their introduction into my network, (currently 380.66_4). The Netgear router is running stock firmware, (V1.0.0.26_1.0.14).
I have been searching for some time trying to discover why I have continual issues with devices when connected to the 5Ghz Band without success. Perhaps someone has a suggestion on what to do or test or try next to stabilize the connections. The consistent disconnects have forced me to connect most devices to the 2.4Ghz band even when they can operate at 5Ghz. Thoughts, comments and suggestions are welcome.
