5Ghz channel selection in AP mode
gnyf
Setting up two 68U's connected by cable.
Have a small issue with the unit running in AP mode.
I can't choose which 5 GHz channel to use - only option is auto or channel 0 ;)
The unit running in router mode have all channels avail to choose from.
Using merlin 374.42_2
Is Auto a problem then ? ;)
Why does the channel matter? Do you mean maybe same ssid instead?
As I roam between the two routers I'd like to have same channel for both.
Bad idea, as they will interfere with each other. Use different channels.
