68U Frozen UI + No SSH Prompt - 384.18
Zoomingrocket
Recently began to notice that my 68U UI & SSH seems to be hung/frozen after router is run for about 2 weeks.
Both UI & SSH will prompt login page or password (ssh) and once entered no page loads or SSH does not give any prompt :(
Hardwire Internet & Wireless continues to function so no direct impacts on router performance.
Hard reboot restores both, I have reset the router and reconfigured settings but would like to understand if I should look at something else?
UI is running on LAN over HTTP 80, no SSL
Router has been stable for last 2yrs, most recent setting change after 384.13 upgrade was enabling Adaptive QoS, other than that most settings are same when original router was configured 2yrs back.
Thanks & appreciate the help!
