Hello,
Can anyone please share what connector is on the 68u for the antennas? I am installing a remote antenna and want to plug it into a 68u. Does it matter which antenna port I use? If I am only connecting to 2.4ghz I should turn off the 5ghz radio? My plan is to receive a WiFi connection on one 68u, plug it into a second 68u that has a LTE device connected and use that second 68u as my router/AP..
Thank you!
Thank you!
