Hey all,
As some know I moved from Florida to Louisiana and have a new apartment now. In that process I was also forced to change internet providers as Spectrum, who I had for years is not here. So, I had to go with Cox. Anyway, my questions are these:
1. After setting the cox gateway into Bridge mode per their support document instructions, everything connected normally with the RT-AX86U. With this said however, since Cox, and Spectrum are two different providers,do I need to change anything in WAN settings such as the mode like aggressive to normal, etc.
2. The other question is, is there a way to clear the router's history without doing a full factory reset. It seems like it remembers clients that were connected to it in my old place, though they show in the offline list. I found this out when doing manual DHCP assignments this morning.
Besides these two areas of questions, everything seems to be working. So, this was more of asking to avoid future problems if I didn't change something I should.
The other question is, should I disable 11b, I don't have any devices, and the gateway from Cox only has g/n support for the 2.4 band enabled. So was wondering if I should tune the Asus to their defaults for better performance in this environment. It's far more congested then where I used to live. However, as mentioned my settings that came with me seem to work ok here as well. Just trying to tune for the new environment.
