MissingTwins
Markdown (GitHub flavored):
** Based on Merlin 380.68_4 Firmware, but should be working on any router that supports Entware.(also tested on 386.3_2) **
Added:19/11/26, all "zt0, zt1, ztzlgf7vul" can be replaced by zt+ for wild matching in iptables only!
1. Entware installation.
`$ entware-setup.sh`
2. Then install ZeroTier using Entware:
`$ opkg update`
`$ opkg install zerotier`
3. Start TUN
You might get this error in step 4 `Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)`, then run this at first.
`$ modprobe tun`
4. Start zerotier service
`$ zerotier-one -d`
5. Check service status, should be 200
`$ zerotier-cli info`
6. Joint zerotie network, before run this cmd, make sure you ___don't___ have ___0.0.0.0/0___ in your zerotier ___Managed Routes___, otherwise you will ___get disconnected___ from the Internet.
`$ zerotier-cli join <your network id>`
go to `my.zerotier.com` to enable your new node. `10.9.8.2` is router, `10.9.8.10` is VPS get your network id from `my.zerotier.com` network, it looks like this `9afac5978a18fe8`
7. Test the network, should not work.
`$ ping 10.9.8.10 -c 4`
ping without '-c 4' or terminated by `ctrl-c` will cause zerotier crashing, if so run `zerotier-one -d` again
8. Add iptables rules
You may run `iptables -v -L -n --line-numbers` first, get an idea of how your iptables looks. please don't just do copy & paste. ACCEPT all data from zerotier.
`$ iptables -I INPUT -i zt+ -j ACCEPT`
Restart zerotier
`$ /opt/etc/init.d/S90zerotier-one.sh stop` or `killall zerotier-one`
`$ zerotier-one -d`
9. Test the network, should work this time.
`$ ping 10.9.8.10 -c 4` #Ctrl+C terminates the ping will crash the zerotier be careful
10. Allow FTP, SSH, WEBUI to be accessed from zerotier
`$ iptables -t nat -A PREROUTING -d 10.9.8.2 -p tcp --m multiport --dport 21,22,80 -j DNAT --to-destination 192.168.9.1`
Or alternative way: quote mark (the key next to the ! key on your keyboard ) around nvram get lan_ipaddr is needed.
$ iptables -t nat -I PREROUTING -i zt+ -d 10.9.8.0/24 -p tcp -m multiport --dport 21,22,80 -j DNAT --to-destination `nvram get lan_ipaddr`
11. Create the script to run zerotier: [URL]https://gist.github.com/meoso/b25bd410c8a54a1a013f0cc2d72b12ee[/URL]
`$ nano /opt/etc/init.d/S90zerotier-one.sh`
`$ chmod 755 /opt/etc/init.d/S90zerotier-one.sh`
12. Setup cron, check zerotier each minute
`$ cru a ZeroTierDaemon "* * * * * /opt/etc/init.d/S90zerotier-one.sh start"`
13. Scripts for booting
/jffs/scripts/nat-start #Changed from init-start to nat-start
/jffs/scripts/wan-start
/jffs/scripts/firewall-start
14. Make all scripts excutable
`$ chmod a+rx /jffs/scripts/*`
**Use these commands to debug iptables**
Reset Packet Counts and Aggregate Size
`$ iptables -Z`
`$ iptables -Z INPUT`
`$ iptables -Z INPUT 1`
include -v to see the entire rule.
`$ iptables -v -L -n --line-numbers`
`$ iptables -v -L INPUT -n --line-numbers`
see all nat tables
`$ iptables -v -t nat -L -n --line-numbers`
The line numbers help with deleting rules.
`$ iptables -D [INPUT|FORWARD|OUTPUT|myCHAINNAME] [Rule#]`
The -n speeds up the process by not doing hostname lookups
`$ iptables -nvL [INPUT|FORWARD|OUTPUT|myCHAINNAME] --line-numbers`
Put print debug info into syslog
`echo "$(date) Started ZeroTier-One" | logger -t "$(date) Started ZeroTier-One" -p user.notice ;`
List all known nodes
`$ arp -a`
**All scripts
Bash:
#!/bin/sh
modprobe tun
Bash:
#!/bin/sh
Bash:
#!/bin/sh
logger -t "custom iptables" "Enter" -p user.notice
iptables -C INPUT -i zt+ -j ACCEPT
if [ $? != 0 ]; then
logger -t "custom iptables" "rules added" -p user.notice
else
logger -t "custom iptables" "rules existed skip" -p user.notice
fi
Bash:
#! /bin/sh
case "$1" in
start)
if lsmod | grep -q tun ;
then echo "mod tun ready" ;
else
modprobe tun;
logger -t "zerotier" -c "modprobe tun started, zerotier-one should start in one minute" -p user.notice ;
exit 0;
fi
if ( pidof zerotier-one )
then echo "ZeroTier-One is already running."
else
echo "Starting ZeroTier-One" ;
/opt/bin/zerotier-one -d ;
echo "$(date) ZeroTier-One Started" | logger -t "zerotier" -c "Started" -p user.notice ; #>> /opt/var/log/zerotier-one.log ;
fi
stop)
then
echo "Stopping ZeroTier-One";
echo "$(date) ZeroTier-One Stopped" | logger -t "zerotier" -c "Stopped" -p user.notice ; #>> /opt/var/log/zerotier-one.log
else
echo "ZeroTier-One was not running" ;
fi
status)
then echo "ZeroTier-One is running."
else echo "ZeroTier-One is NOT running"
fi
echo "Usage: /etc/init.d/zerotier-one {start|stop|status}"
exit 1
esac
exit 0
Updated 2019/11/05
If you experienced issues with zerotier ssh and webui. Such as putty hangs with outputting 10+ lines.
Try to change MTU from default 2800 to this or smaller value `ifconfig ztzlgf7vul mtu 1388`
Updated 2019/12/06
Removed the confusion over the iptables rules.
Updated 2021/12/22
Formatting
Updated 2022/09/01
Add warning about 0.0.0.0/0 in Managed Routes will cause losing the Internet.
