Hello,
I want to minimize the amount of wires in my room so im moving to wireless, network and audio (Bluetooth headphones and such).
I purchased DIR-825 router + DAP-1522 Bridge + DWA-160 adapter
I have a couple of questions if please if you don’t mind: ( the distance between router and Wireless adapter and bridge is 2 meter in same room, both on opposite sides of one desk)
1. I purchased adapter for my PC and Bridge for my xbox 360 and PS3, now all these 3 are located on same desk and I never use all 3 together, it will be PC+XBOX or PC+PS3
My question is can I use DAP1522 Bridge with all these 3 devices or it will be better to use PC with DWA160 adapter and Bridge with consoles only?
is there any benefit of dividing them? Or maybe I should eBay the DWA-160 adapter and keep everything connected to wireless bridge?
2. currently I disabled 2.4Ghz band on all devices and everything works on 5Ghz/40mhz, the router comes with 2 antennas, so by disabling one band will it free more resources / bandwidth to another one?
3. there is an article on this site about how bad is to use mixed mode wireless, that it affects N speed.
So if I use 5Ghz as N only and 2.4Ghz as B only (for my PSP) will it affect the speed of 5Ghz N?
I hope its not too many questions, thank you, Benny.
