Daniel Dirksen
So I am in the middle of testing Microsoft's Always On VPN solution for my work, on the client (not the router).
With my home AC-68U VPN performance is drastically worse over Wifi then LAN.
Generic internet speed tests (no VPN) on the device comparing the 2 is what I would consider expected, less consistent and slightly slower on wifi. 220-270 Mbps vs 250-300 Mbps.
File transfers over the Win10 built in MS IKE VPN client is averaging 10 MB/s on LAN and 1 MB/s on Wifi.
I updated the firmware (Asus) and reset to default, changed SSID, disabled some features like beaming.
This did improve performance (to 1.3 MB/s) but still seems to be much to low compared to LAN.
Any thoughts/tweaks? Still need to test other factors, but this behavior suggests an issue with ASUS wifi to some degree (suppose the clientside wifi driver as well).
The only settings that appeared obvious was the WAN\Nat Passthrough options, all are enabled (IPSec I would expect to be required) except PPoE.
Thank you for your suggestions...
Dan
Dan
