AC-86u vulnerability tracking post-EoL (asuswrt-merlin 386.14_2)
JTnola
Wondering if anyone is tracking (unpatched) critical vulnerabilities for End of Life (no longer supported) AC models running asuswrt-merlin FW-386.14_2 …?
Thank you!!
How would anyone reasonably know an unpatched vulnerability existed? You must assume they do exist, but tracking them seems futile if you know no future firmware update is coming. I’m sure there are hackers out there tracking them for future exploitation.
If you’re just comparing to stock firmware releases, that’s easy enough but not always directly comparable to a Merlin release.
Time and energy are better spent saving up for a new router and relegate the AC routers as access points behind a more current router/firewall.
i see your latter point, in re: “time better spent”, but it’s entire plausible that someone who regularly pays attention to such things would be aware of vulnerabilities impacting asuswrt/asuswrt-merlin that would only be rectified by ongoing FW updates.
No firmware updates are expected so tracking vulnerabilities for an EoL device is kind of pointless. Lock the router with nothing exposed to Internet and just continue using it. No need to stress yourself. There is no guarantee supported router won't be hit by malware. It happened recently and based on user reports "unsupported" devices had no issues, "supported" suffered some damages.
I wonder if there's a Windows 95 unpatched vulnerabililty list floating around. I could really use one. I know it's EoL. Asking for a friend.
No problem. Here you go:
No problem.
⬆️ Well, that right there sure sounds like tracking to me ;)
But, I hear you. Thanks!
This "tracking" is possible because of SNB Forums community. When multiple people start complaining about the same issue - something is obviously happening. Stop by from time to time and you may get early warning. With EoL device though you may never receive a fix. Most of the time workaround options are available for unsupported devices. The last attack was targeting AiCloud as an example. If you never used it or had it disabled on time - all good. At least this is what we know from user feedback.
