AC-RT88U and DNS settings?
zachary brown
Hello,
Just signed up to ask this question.
I have the Asus AC-RT88U and recently bought a ras pi to tryout pi-hole and Im having weird issues with the router and the DNS settings.
Under the WAN section, I set the ras pi ip address to my DNS server 1 and Google's to 2 as a fail safe. I originally left the LAN DNS section blank. Doing this I still get ad's served to me. So then I set the LAN DNS to the ras pi and everything worked fine, no more ads. I've now set the LAN DNS to blank again, and only the ras pi ip address as DNS 1; no ads. Add the Google DNS and I get ads. Set both to some random ip, no DNS resolving at all.
Am I doing something wrong? Has anyone else had an issue like this? Id like to have a fallback dns server listed in case the ras pi goes down.
Sounds a bit strange. Try SSH'ing into the router and issuing the following command. Maybe they have set "all-servers" and your pi-hole is too slow.
cat /etc/dnsmasq.conf
zachary b,
I'm going to assume that you are running stock firmware and not running Merlins' on your RT-AC88U since you only have one DNS option in LAN setting? Ok, if that's the case you need to do this:
1. Set LAN DNS to rPi address
2. Set WAN DNS1 to rPi address and set WAN DNS2 to Google's DNS address.
This will setup a backup as you wanted. If your rPi is down, your LAN clients will look to your RT-AC88U for DNS and will find rPi (DNS1) & Google DNS (DNS2). Since rPi is down, it will use DNS2 in your WAN setting. Okay? Just remember that when your are force to use DNS2, you will see ads. To eleminate this, get a second rPi and config that too with Pi-Hole. Put the second rPi address into WAN DNS2 and now, should one rPi go down, the other picks up... thus no ads.
I have two rPi 3s setup this way. No ads... well, fewer ads. There are still some ads Pi-Hole can not fully block. You will still see youtube ads but hopefully the next version of Pi-Hole will solve that with FTLDNS and regex blocking.
Hope that helps.
Thanks for the help; both of you. I will try the SSH command when I have time to play around with it. In the meantime, I will set the DNS settings like I had them before (and how they were recommended above).
Hey Zachary b,
I recall having similar issues as you stated when I first installed pi-hole. Did you by chance flush your dns cache on all client after installing your rPi? Reboot your router after you made the recommend changes and flush dns. Example; under windows using command prompt, issue this command: ipconfig /flushdns
Also, if you care about statistics and have your pi-hole query logging (should be by default), you MUST set rPi as your DNS in LAN settings. So, basically set it as I recommend for LAN & WAN above. If you don't, when you log into pi-hole's webgui (http://your-rpi-ip-address/admin), all queries well be logged as being made by your router only and rPi's (localhost, 127.0.0.1).
To make sure all your rPi is resolving your DNS queries, make sure to have a browser tab open to http://your-rpi-ip-address/admin and see if Total queries, Queries Blocked, etc. are being counted (going up) as you browse the web.
Good luck.
Ill flush the dns on my windows pc and see if that helps as well.
Its been working just fine lately. I have the LAN dns set to the pi-hole and my PCs and MBP automatically get the pi-hole as its main dns and the gateway as a second. So if the pi-hole were to fail, it should revert back to the gateway which will use my wan dns 2 of 8.8.8.8.
Thanks everyone!
zachary b,
Hope that helps.
Old post, but this has helped me be aware of better arrangement and configuration of my Pi's setup. Thanks. Thinking of a way to make the 2nd Pi response slower, so that clients would never query it when 1st Pi is still available...?!
