AC3100 best firmware
Mario64
Hi all. I’m having all sorts of issues with 32799. Devices, both wired and wireless, keep resetting and/or hanging. Can anyone recommend a good stable firmware? Should I revert back to the prior 32x release or down to the 21x series? Thanks
Dont have issue with latest firmware
I will try power cycle and clear nvram first
power off router for 30+ sec, hold wps button while powering on
wait for the power led start flashing/blinking, then release the wps button
wait for it boot up properly and then reconfigure everything. dont load the old configuration.
Thanks but there are multiple reports of issues with 32799 and my issues started immediately after installing it
Thank you! Testing Merlin 384.5 now. Hoping for success
Make sure to factory reset and power cycle before entering fresh settings. The issues with the firmwares as of late are due to asus making constant radicle changes and adding new features and updating wireless drivers. Be sure to do both and u should be fine.
