ac3100 mesh node 5Ghz missing
Island
Greetings and happy New Year all! Just a quick question and some help if possible. My Mesh network is running fine. Using 4 Asus routers in my 2 story 3900SF home. AX86u as main and another AX86u, AC86u and my 3100. Current Asus firmware is up to date. I noticed this morning that when I go into the Asus Web GUI, everything looks fine, except when I go into the 3100 mesh management. All my devices are ethernet connected. The 3100 shows connected via ethernet but under wireless, the 5 Ghz channel is missing.
Also, when I go to the enable radio tab, 2.4 Ghz is the only one listed. I know the 5GHz is working, as the 5Ghz activity lights are flashing on the 3100 and when I look at connected devices, I see a few of my devices connected to it via 5 Ghz. Is this a bug? The router had been connected previously via wireless mesh using the 5 Ghz channel for it's uplink. I was able to move it to another location so I could connect it via ethernet which it shows now as it's uplink. I would assume this is a bug and removing it as a node and resetting it and then adding again would be the best course of action to take? Thanks all!
