elrengo
Hi everyone, I need your help and your knowlodge. I've Cablemodem for my Internet connection. The modem will be use as WiFi Router and as Modem (bridge). In my case is configure as Modem or Bridge to use my router. I've two Asus routers:
AC3100 and RT-AC66U_B1. The AC3100 is used as main router (aimesh) with Merlin Firmware with the AC66U_B1 is configured as aimesh node using ethernet cable connection with stock firmware.
The solution works fine for many years. Yesterday my AC3100 have not Internet connection. I do everything in my mind:
After that the AC3100 show white led with wan connection but I can navigate in Internet after some reset the led return to red and the message on Asus configuration website with "Your ISP's DHCP does not function correctly". After that reconfigure the aimesh setting and both router works together again but with no Internet.
After try all the configuretion proposed in this topic with no Internet Connection:
My last test to discard hardware issues. The router configuration allow to swith what will be the primary WAN port: WAN or the LAN port defined to use.
When the WAN port is Primary:
I do not know what else to test.
- Restart the router
- Restore default configuration
- Using a MAC Clone of my computer with out restart cablemodem
- Upgrade last stable Merlin Firmware (384.14_2)
- Restore default configuration again.
- Change the Ethernet cable that connect router with Cablemodem (allway have link (green led on cablemodem)) but I would like to try.
- IPv6 allways will be disable
- Change the following WAN setting but not work
- "DHCP query frequency" -> "Normal"
- "Extend the TTL value" -> "Yes"
- "Spoof LAN TTL value" -> "Yes"
- Using WAN port to WAN the message is: "Your ISP's DHCP does not function correctly".
- Using the LAN port as secondary WAN will be connected to Internet.
- Usin LAN port to WAN the message is: "Your ISP's DHCP does not function correctly".
- Using WAN port as secondary WAN will be connected to Internet.
