AC3200 many clients connected
sativa
I have explored but no luck, apparently my Smart TV has 3 connections, connected to my Router (Asus AC3200, Merlin firmware):
upload_2017-1-27_23-9-14-png.8367
Any ideas? The only connection into the TV is 1 smart TV box (Now TV), nothing more. Moreover, the Now TV appears separately in the Client List.
I am getting paranoid that 1-2 people have connected into my TV? lol
Two things to check try:
Does your TV have both an Ethernet and a WiFi connection? If so disable one or the other.
Give your TV a static IP. Perhaps it is connecting and disconnecting frequently so in the list of connected clients it has multiple IPs which the router is reporting as multiple clients.
Hi @sativa ,
It should be "mac clone", some driver will copy the mac as clients' mac.
ex. A, B, C connect to repeater or media bridge(ex. RT-AC68U), when you use RT-AC68U to connect PAP, you will find PAP show 4 RT-AC68U's MAC in client list.
For samsung TV, I think you use Samsung TV to connect RT-AC68U, and some devices are under Samsung TV.
Thanks,
Vanic
