Yeah it is, they had overclock it.
You can test whatever Broadcom CPU you want, BCM4708, BCM4709, BCM4709C0 or even BCM47094, if they are set at same clock speeds (overclock at 1.4GHZ) they will perform the same, tests results don't lie.
Now if theres any other new "feature" from newer models (which i doubt) the only way is to check the datasheet, like i said several times before this BCM47094 it's "more of the same" or "sand to the eyes", simply overclocked and renamed.
I know that, but i was only refeering to the CPU performance on them, it doesnt bring anything new, simply more clockspeed. I simply deal with the facts, testing RT-AC68U/RT-AC87U vs RT-AC88U doesnt convince me at all, the only advantage is the USB speeds (due to SDK7 usage) and extra memory on it, as you know you can see the same USB speeds on RT-AC87U once its under SDK7 aswell, and if they would upgrade also older models RT-AC56U and RT-AC68U to SDK7 you would see the same performance increase, its not the hardware but the software.You need to stop thinking of the BCM470x as being "just a CPU". Yes, those variants ALL use a Cortex A9 - Broadcom never said otherwise. But this chip is a complete SoC. The rest on the chip isn't the same.
So no, it's not "just an overclocked BCM4708". That SoC also contains the USB host, the Ethernet switch, Broadcom's Flow Accelerator engine, the PCI-e bus, memory controller, and so on. These components are just as important, and they do get upgraded.
RT-AC88U/RT-AC3100 (BCM4709C0) CPU:
Are the BCM4709C0 and BCM47094 the same thing? I see both model names mentioned on the web, however BCM's own website only mention the BCM47094.
Offloading the radio to the BCM4366's own CPUs should help with high client load performance on the latest generation of routers.
it'll help a bit - but performance is getting a bit inverted - we've seen fantastic levels of development on WiFi SoC's, but we're at a point where the Router SoC's are getting saturated with higher bandwidth needs on both the WAN and LAN sides, along with more application loading on the cores inside the Router itself...
Not sure who makes the first move to either ARMv8, or to better ARMv7 cores (QCA is already there with their Krait's on their IPQ's), either Cortex-A15, or one of the 64 bit variants...
Cortex-A9 isn't a bad chip, but it's getting along in years... been a good run for that core...
Welcome To SNBForums
