As per GRC.com test, port 22, 80, and 443 are open using common port test. All else is closed. Nothing is in stealth. I'm used to seeing everything in stealth, but admittedly it has been a few years since the ac56u has been used as a router and checked at GRC. I got a new ISP yesterday, and I put the ac56u back into service as a router. After I saw the poor results at GRC (using Windows 10 and Windows Defender as well), I reset the router to factory defaults and reconfigured it turning off every service I could (i.e. USB/AICloud, etc). I tested again with the same results. I then installed zonealarm and turned public and trusted zones to high. I tested at GRC again with the same results. What am I missing? I can tell from reading this site that most of you are way above my intellect level. Please type slowly
Should I be concerned?
The Asus Router is using the latest Asus firmware (3.0.0.4.382_50624)
Just had a thought. Does GRC probe the network, or just the computer I’m on? If zonealarm made no difference to my results perhaps it isn’t my computer that is the problem. I have all kinds of connected devices on wifi (Roku, thermostats, Alexa, google, etc).
Thank you in advance.
