AC66U (AC68U) firmware 384.18 shows 384.17
nakti
As the title, cant see anywhere in gui that it says 384.18 after updating firmware from 384.17 and now it doesnt search for new firmware as it maby has latest but shows wrong number?
If it is showing 384.17, you didn't upgrade it.
I would recommend 384.19 Beta 1 anyway today. :)
See if some of the steps in the link above don't help you get to the firmware version you want to be on.
And double-check that you are downloading the 384.xx file for the RT-AC68U and not for the RT-AC86U for the RT-AC66U_B1 router you have and want to upgrade.
I did upgrade as i do always and the firmware was 100% and I did log in again. First time it didnt upgrade if it was anything fault. I will try beta. Thanks, and I meant ac68u and not 86 I wrote wrong.
