Bojamijams
Has anyone noticed this issue before?
I set my channel on the 2.4ghz band to 1L and after it applies the setting it is actually channel 6. I tried setting to 2L, still channel 6.
Then I changed the bandwidth from 20/40 to 40 only and tried 1L again, this time it picked channel 3.
I've already cleared the nvRAM. Weird, no?
Edit: Okay the second time around it set the channel to 1 but only if I keep the bandwidth to 40Mhz. Is that worse then keeping it at 20/40?
