Hi guys,
Just bought an AC68U (could not wait for AC87)
Just read that because of FCC regulations firmware from 376.xx and up will be crippled. Is that correct?
To be able to unlock channel on both 2.4Ghz and 5Ghz band i will have to stay on 374.xx firmware?
Im planning on doing the following to the router after flashing to 374.43.2 (best firmware atm?)
nvram set wl0_TxPower=1000
nvram set wl_TxPower=1000
nvram set wl1_TxPower=1000
nvram set 0:ccode=#a
nvram set 1:ccode=#a
nvram set 0:regrev=0
nvram set 1:regrev=0
nvram set wl0_country_code=#a
nvram set wl0_country_rev=0
nvram set wl0_reg_mode=off
nvram set wl1_country_code=#a
nvram set wl1_country_rev=0
nvram set wl1_reg_mode=off
nvram commit
reboot
Will this work? Is there anything i should be aware of? any other tweaks that could be done to get the most potential out of this router?
BTW. My bootloader version is 1.0.1.7. I cant seem to find anything on the forum higher than 1.0.1.6. Dont know if that makes a difference?
Thank you for a great forum
Regards
Jacob
nvram commit
reboot
Regards
Jacob
