AC68 problems with portforwarding WHS2011
Solar Legend
Hello, i have problems with port forwarding on my new Asus AC68..
I have my windows home server set up on DHCP to static adress, and in the router i have port forwarded ports like 80, 3389,4125,2021 and 443 on to my server adress.
These are ports that should allow me to connect to the server with Remote desktop while im out travellig.
All this worked good on my previously Asus N66U..
Anyone have an idea about what im doing wrong here?
If you're testing them from within your local network they won't work if HW acceleration is enabled. There is something buggy with that module. From outside your network they will work fine. If you need them to work from within your network too then disable HW acceleration.
Well is HW acceleration enabled by default? I btw just updated to latest Asus firmware 3.0.0.4.374_339. Using remote desktop from within my local network is no problem, the problem is when i try to connect from outside.
It's enabled by default, unless an incompatible feature is enabled. To force disable it, go to LAN -> Switch Control.
Thank you guys:) HW acceleration off did the trick it seems... Btw am i missing alot of performance by turning it off?
Merlin do you have a good fw for Ac68? i used yours on my RtN66u and enjoyed it.
Look for a thread called 'a dose of quicksilver'.
