When it is acting slow, go in via ssh and cat /proc/cpuinfo
What is your BogoMIPS showing?
I've checked packets instead of that. I found following info when it's slow.
'Ignored Unknown Record'
It's related in SSL, MTU, TLS. I think there is the MTU issue with 3.0.0.4.384.21045.
No. I use IPv4. I've never seen this kind of issue with ASUS router. I mean 'Ignored Unknown Record'. I know what it is. That's why I suspect the firmware. I'm still looking for the cause.Do you get IPv6 from your ISP?
I don’t use stock firmware so can’t really test this, but I highly doubt upgrading firmware would change your MTU settings. What’s it set at?
You’re seeing ‘Ignored Unknown Record’ from Wireshark right? I’m guessing the TLS packets are snapped at the MTU length?
I don't use PPPoE. The value 1492 is from PPPoE menu though.Do you use PPPoE? If not change MTU to 1500 and see if that helps.
Yes it's auto. I checked and did a lot of things such as rebooting and power off. I'll try NVRAM clear later.Then the PPPoE value of 1492 is not relevant to you. I’m assuming your WAN Connection Type is set to “Automatic IP”? If so, have you tried rebooting/power cycling the modem? It might have been stuck in a weird state with the wrong MTU when you upgraded the router. Worth a shot.
Welcome To SNBForums
