AC68U not seeing data use from an Aruba
tmcb82
I work from home, so my work gave me an Aruba 203R (VPN) to connect to my RT-AC68U. It has/is working great but something I recently noticed is the router never "sees" it using any data. I have QOS set up and (when I am actively using my work computer connected to the Aruba) I can go to the "Bandwidth Monitor" and "Classifications/Tracked Connections" it never shows any use. I am using FreshJR's v8.2 script to route all traffic from the Aruba into the VOIP category (I want it to be a high priority). I assumed the "Tracked Connections" might be a vague (since the data is encrypted) but it's totally invisible. Am I missing something?
Thanks!
You may want to update FreshJR QOS to 8.4, which addressed some bugs. It may fix what you're currently seeing. ;)
I'm using 8.8 now and it is still invisible. I also just uninstalled FreshJR QOS and tested and it is still doesn't show up... still can't figure out why...
