AC68U - WAN Port Broken
Zoomingrocket
Hello everyone,
So had bad thunderstorms today and had very bad electrical surge after which seems like my WAN port is broken
Tried with a spare router and immediately got connected to internet.
So short term i enabled dual WAN and leveraging LAN port 1 for now. Do i need to reconfigure anything else? It prompted to verify QoS before applying and i use Adaptive QoS.
Looks like finally time to pull trigger for new Asus router, AX68 or AX86 or AX88
Thank you in advance!
Make the RT-AX88U your last choice (it's usually the most expensive too).
Reboot the router a couple of times in the next couple of hours or so. If everything works, you may want to wait for the best sales on a new RT-AX86U or RT-AX68U.
Thanks, Anyway to rule out that WAN port is gone gone?
I unplugged the router for 10mins, but no luck! No link LED & WAN IP if I plug Internet cable into WAN port, but LAN port LED will immediately light up upon plugging in & WAN IP
Anyone using ethernet surge protector & recommend particular type? I know its like once in a couple of years where a large surge will create a problem, but nevertheless, i did overlooked that my network equipment over WAN ethernet is not surge protected!
I ordered a pair of watchfuleyes solution plugin ethernet surge protector from Amazon! Lets see how it helps and watching for some Thanksgiving deals on AX86U
The same thing happened to one of my AC68Us a few years ago. Lightning struck a tree located about 15 feet from the house and 25 feet from the AC68U. The WAN port was completely dead after the strike, but the router was fully functional otherwise. It also killed the Ethernet port on the cable modem the AC68U was connected to and damaged a switch.
The damage caused by the surge was completely limited to Ethernet devices. The cable modem also appeared fully functional except for the Ethernet port. I don't think the surge could have entered on a power cable or the coaxial cable and damaged only the Ethernet ports. I had surge protectors on all power cables and the coaxial cable. The cable connected to the damaged switch was the only Ethernet cable connected through a surge protector on a UPS. I believe the lightening strike was so close that high voltage was induced on the Ethernet cables. I'm not sure if having an Ethernet surge protector at each device would have helped or not.
You might want to look for signs of a very close lightning strike if you haven't already. In my case, the tree had bark blown off the trunk.
