AC68U Wi-FI radical fluctuations on two different routers
Q05039
I have one AC68U router setup and on both the 5G and 2.4G bands the wi-fi signal in fluctuating radically from -50dB when "on" and then the signal drops to 0db for a few seconds, then resumes back in the -50db range. This issue is occurring on both bands. I have used Netspot to see these fluctuations. They are not consistent as they sometimes go away for 15 to 30 minutes and then come back and fluctuate for several minutes in a row. I have my 2.4G band on Channel 6 and the 5G band on Channel 157. I have tried changing channels to no avail. Also I don't seem to be getting any interference from neighboring routers as I have no one close to me using channel 6 or 157. At first I thought I had a bad router so I bought a second AC68U and placed it in the basement and set it up using channels 1 and 161 and the same thing happens. Both routers have been loaded with the latest Asus firmware 3004.386.41634 and I have used factory default settings. I would appreciate any help I can get as I am out of options. What things can I check or change that might be causing this issue? I have attached several view of router settings and Netspot results that show the issue.
Bad power?
Try a different tool such as WiFi Analyzer on Android?
Did you reset the firmware before using it?
Reset FAQ
Reset Button/webUI Restore
WPS Button Hard Reset
OE
Like ozarkedge says could be poweroutlet or your extension/strip. if two routers are doing the same thing, doubt your router is the issue.
