AC86U - 384.17 - Lost 5GHZ, Rebooted Manually, appears but says wrong password
wizin
I changed password, put back original but its wrong pwd for all of them
Log attached, any help
https://imgur.com/DvSyu6S
4 devices - all have same issue, I tried the reset network settings on them, turn wifi on/off, forget network etc
The password has been the same for long time and even changing it doent work, but strange it just disappeared in the first place
I found similar issues in 384.15, 16 and went back to 13 which was stable but i assumed 17 would fixed
Is this a known issue?
DvSyu6S
DvSyu6S
  • new 1.txt
So went default ASUS firmware and it still cannot recognize my 5GHZ, is it dead?
Give it a few manual reboots and some time,, had that problem with my 5300 when i downgraded from 384-18 to 384-17
My issue went so bad, I had to do a rescue mode
I dont know what version to pick now, its in factory default
Many of us have had great success with Asus 384-81918. Use Dual Band SmartConnect with fixed channels and set 2.4 GHZ to 20 MHZ bandwidth. Use a SSID of no more than 8 letters. Leave professional wifi settings at default.
I set it up with my own name/password and now its not accepting it, even the default one is not working. I had this same issue earlier where I did a factory default and then from there it went bad as I tried .17 and it wouldnt mount JFFS, so I tried few times with partition on next boot and custom scripts on but then it went into a loop for which I had to use rescue mode
I'm really interested to understand more about this advice as I use longer SSIDs and have found Smart Connect issues and WiFi behaviour quirks (but not on a RT-AC88U as I have a RT-AX88U) - is there a thread where I can find out more of the reasoning behind this advice?
Had an 86U completely use all 5GHZ functionality earlier this year. After a reboot, something would connect for ~1-2 minutes, and then nothing could ever again. All devices could see it, but nothing could connect. RMA-ed with Asus, and pretty much got a brand new 86U from them. Apparently this has happened to other people on the forum.
I have yet to try more but now on factory default s/w and its working fine
@wizin the following link may help.
https://www.snbforums.com/threads/ax88-packet-loss.62891/#post-563326
If the router is stable afterward, the M&M Config and ideally the Nuclear Reset guides may be useful too (see the link in my signature below for those guides and more).
I tried the above, and did partition JFFS and use scripts option, did manual reboot x 3 times, but I have the same issue
Is router dead? coz I read somewhere when JFFS cannot partition, its an issue
EDIT: Worked after 4 reboots - 1 after enabling, 1 after disabling
