AC86U 386_1 suddenly rebooted itself - does 386.1_2 fixing it? Just happened today
jpthsd
Hello,
I recently upgraded 386_1 both AC86U Main AiMesh and another AC86U AiMesh node. It's been 3 days solid stable. Suddenly out of the blue, the AiMesh main AC86U as above my head over the shelf, it started rebooting itself..
Anyone experience AC86U 386_1 rebooting itself? Any fix? or just upgrade again to 386_1_2?
Thank you!
Hi, I'm using v386 on my AC66U_B1 and it always reboots after couple of minutes/hours, no matter upgrade from v384 or a fresh install.
But v384 don't have this problem, this really annoys me.
EDIT: tried 386.1_0 and 386.2_2, upgrade from 384 or fresh install, both randomly reboots.
I have the same problem, ac68u ac86u ax86u all have random reboot issues.
Range from minutes to days, 386.3_2
There is nothing specious in the log, private data has been censored.
From Oct 22 05:58:08 to Oct 22 06:15:36 there is a 20 minutes blank , doesn't seem to be due to a power failure.
Oct 22 04:44:01 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 04:44:01 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 04:54:51 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind B3:A4:AC:E3:8C:AD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 22 04:54:51 wlceventd: wlceventd_proc_event(508): eth6: Disassoc B3:A4:AC:E3:8C:AD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Oct 22 05:43:22 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:43:22 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:43:22 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind B3:A4:AC:E3:8C:AD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 22 05:43:22 wlceventd: wlceventd_proc_event(508): eth6: Disassoc B3:A4:AC:E3:8C:AD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Oct 22 05:43:23 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:43:23 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:44:22 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind B3:A4:AC:E3:8C:AD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 22 05:44:22 wlceventd: wlceventd_proc_event(508): eth6: Disassoc B3:A4:AC:E3:8C:AD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Oct 22 05:49:52 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:49:52 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:49:53 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind B3:A4:AC:E3:8C:AD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 22 05:49:53 wlceventd: wlceventd_proc_event(508): eth6: Disassoc B3:A4:AC:E3:8C:AD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Oct 22 05:49:54 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:49:54 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:50:52 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind B3:A4:AC:E3:8C:AD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 22 05:50:52 wlceventd: wlceventd_proc_event(508): eth6: Disassoc B3:A4:AC:E3:8C:AD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Oct 22 05:58:08 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 05:58:08 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
May  5 13:05:08 kernel: klogd started: BusyBox v1.25.1 (2021-08-06 17:48:21 EDT)
May  5 13:05:08 kernel: Linux version 4.1.27 (merlin@ubuntu-dev) (gcc version 5.3.0 (Buildroot 2016.02) ) #2 SMP PREEMPT Fri Aug 6 18:32:35 EDT 2021
May  5 13:05:08 kernel: CPU: AArch64 Processor [420f1000] revision 0
May  5 13:05:08 kernel: Kernel command line: coherent_pool=1M cpuidle_sysfs_switch
May  5 13:05:08 kernel: Virtual kernel memory layout:
May  5 13:05:08 kernel:     vmalloc : 0xffffff8000000000 - 0xffffffbdffff0000   (   247 GB)
May  5 13:05:08 kernel:     vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000   (     7 GB maximum)
May  5 13:05:08 kernel:               0xffffffbe00000000 - 0xffffffbe00700000   (     7 MB actual)
May  5 13:05:08 kernel:     fixed   : 0xffffffbffabfd000 - 0xffffffbffac00000   (    12 KB)
May  5 13:05:08 kernel:     PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
May  5 13:05:08 kernel:     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
May  5 13:05:08 kernel:     memory  : 0xffffffc000000000 - 0xffffffc020000000   (   512 MB)
May  5 13:05:08 kernel:       .init : 0xffffffc0006a7000 - 0xffffffc0006e0000   (   228 KB)
May  5 13:05:08 kernel:       .text : 0xffffffc000080000 - 0xffffffc0006a6274   (  6297 KB)
May  5 13:05:08 kernel:       .data : 0xffffffc0006e1000 - 0xffffffc00072cbc0   (   303 KB)
May  5 13:05:08 kernel: Broadcom Logger v0.1
Oct 22 06:15:36 ntpd: Initial clock set
Oct 22 06:15:36 rc_service: ntpd_synced 2250:notify_rc restart_diskmon
Oct 22 06:15:36 rc_service: waitting "stop_samba" via ip-up ...
Oct 22 06:15:36 Samba_Server: smb daemon is stopped
Oct 22 06:15:37 Samba_Server: daemon is started
Oct 22 06:15:37 wlceventd: wlceventd_proc_event(527): eth6: Auth B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
Oct 22 06:15:37 wlceventd: wlceventd_proc_event(556): eth6: Assoc B3:A4:AC:E3:8C:AD, status: Successful (0), rssi:0
