AC86U drops Aimesh randomly losing functionality.
Keyser-_-soze
Has anyone experienced this, there aimesh feature just disappear and if you log into router they dont show up on network map homepage.
After a reboot everything is back to normal and the aimesh works and shows up once again network map router homepage.
Do I have a defective AC86U.
Other router is AC3100.
Your symptom description is a bit vague...
The first thing to do is to know this FAQ:
https://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
Then you likely need to Reset/Initialize your devices and rebuild your AiMesh from scatch. That will establish a known starting point to consider any remaining issues further.
OE
