NeeWii
[Also posted to the Asus AC Routers forum - apologies if one of these posts is in the wrong place]
Hello, does anyone have any experience with port triggering on the RT-AC86U, and could advise if there is a known issue or if I have set this up incorrectly? I'm looking to use port triggering, rather than port forwarding, as I have two xboxes in the house that I will use interchangeably, and I would prefer not to have to reconfigure port forwarding every time I change xbox. Having set up triggering per the below image, I'm still getting "Nat Type: Moderate" in Modern Warfare.
[Edit] - I should probably add, I do have uPnP enabled already, which works great for getting open NATs simultaneously on both Xboxes within their OS Settings, but Call of Duty Modern Warfare doesn't seem to get picked up by the uPnP at all and the ports are not getting opened/mapped - hence the need for port triggering.
I'm running Merlin firmware v384.13.
Ports required to be forwarded per https://portforward.com/call-of-duty-modern-warfare/ are:
My Port Trigger config on the WAN settings page:
Thanks in advance!
Thanks in advance!
