AC86U RT Firmware 3.0.0.4.384.81918
DarkKnight75
New firmware showed up in my AC86u router GUI, any guinea pigs yet?
I can see release notes via ASUS router app, not up on ASUS website yet. Looks like bug fixes.
Thanks for that
Just ran the upgrade. Will let you know...
Edit: So far so great! Have noticed no ill effects with this upgrade. All clients connected as they should. WIFI signal still seems strong (but I discovered a new Netgear router in my neighborhood that is set to 40 MHZ in the 2.4 GHZ band and is causing interference!)
Just ran the upgrade this morning - so far no issues, though I'm running the 86U as an AiMesh node.
Click on the version link for release notes, if they load... they don't yet.
Dirty upgrade to 81918 seems ok 5 minutes in.
OE
i'm too scared to jump in. i'm so happy with the last one :D
Fear is the path to the dark side. ...
4 hours 10 minutes up with zero issues on this firmware! Just do it...
Was the download/upload dials (missing numbers) in Adaptive QOS dashboard fixed?
just updated and it was the first thing i checked, unfortunately the numbers are still missing on a dirty update.
Firmware version 3.0.0.4.384_81918
- Release Note -
Bug fixes and improvement:
- Fixed game setting page UI bugs.
- Fixed AiCloud share link bugs.
- Fixed AiCloud connection bugs with AiMusic App.
- Fixed Cloud sync bugs.
- VPN clients can be turned on/off by the ASUS router app.
- Fixed offline client removing problem with ASUS router app.
- In the previous version, the certificate for https login needed to be installed again after system reboot, and this version fixed this problem.
- Adaptive QoS supported more apps
Work-From-Home: WeChat WorkВ®, RescueAssist, Tencent/VooV MeetingВ®
Learn-From-Home: LinkedIn LearningВ®, BinkistВ®, SkillshareВ®, edXВ®
Media Streaming: SiriusXMВ®, BilibiliВ®
Indoor training: The SufferfestВ®, Bkool FitnessВ®, TrainerRoadВ®, RouvyВ®
Download: FW_RT_AC86U_300438481918
CRC32 : 1350EAAB
MD5 : 892A6E8A8C4E27BDD1C7FF2BFBD92DF6
SHA-1 : 28FB7BB5051BD6DA667568594E281F33908A8F24
Wow, what a disappointing list of fixes: mostly crap related to the useless "app" (an unnecessary security hole, IMO), plus a load of extra QOS categories for the marketing department. Yawn...
First stable release in my case. Fixed performance issues ive had after few hours with previous firmware.
I am seeing something new in the system general log using this firmware:
roamast: [EXAP]Deauth old sta in 0 0: F8:6F:C1:78:B6:E9
Never had this before appearing in my system log, until this firmware.
My current NVRAM system log level is set at 5.
Not sure what this means?
Anybody else seeing this?
I did do a dirty upgarde from the last current firmare.
Here is another entry into the system general log I am seeing for first time using this firmware:
ahs: [read_json]Update ahs JSON file.
Whats this about?
Whats this about?
Signature file download for a new Asuswrt service (Auto Healing System) that can "self-heal" a few detectable issues.
You might get lucky with the next update :
Fixed errors "mememememe" I'm the only one in the world running this router.
Changelogs are never complete. Quite a few fixes/changes aren't mentioned in them.
I have such spam appeared:
May 28 17:14:28 acsd: eth6 received event: MAC tx failures (exhaustion of 802.11 retries) exceeding threshold(s)
May 28 17:14:29 acsd: eth6 received event: MAC tx failures (exhaustion of 802.11 retries) exceeding threshold(s)
May 28 17:24:42 acsd: eth6 received event: MAC tx failures (exhaustion of 802.11 retries) exceeding threshold(s)
May 28 17:24:52 acsd: eth6 received event: MAC tx failures (exhaustion of 802.11 retries) exceeding threshold(s)
May 28 17:27:03 acsd: eth6 received event: MAC tx failures (exhaustion of 802.11 retries) exceeding threshold(s)
