[AC86U] Smart Connect rule
dsancho
I can't figure out how to setup correctly smart connect rules... I made a lot of research on google and on this wonderfull forum but I still lost.
I just want to connect all my ac devices to the 5Ghz band unless the 5Ghz bandwidth utilisazion is greater than 80% for example.
Could you please help me ?
Thanks !
David
lorkadiscovery
Thanks !
David
Maybe like this? Im no expert on it as the docs for it are not exactly straight forward.
dsancho
Thanks I will try this !
OzarkEdge
Part of the Furniture
D
Deleted member 51572
Guest
ime, Smart Connect isn't so smart at all, and configuring all those esoteric parameters is ridiculously convoluted, so I've turned Smart Connect off and simply allow wireless devices to select the band which works best for them. you don't need Smart Connect.
